Ana içeriğe geç
IBM ThinkPad T30 Optical Drive Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T30 Optical Drive Replacement, Battery: adım 1, 3 resimden 1. IBM ThinkPad T30 Optical Drive Replacement, Battery: adım 1, 3 resimden 2. IBM ThinkPad T30 Optical Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad T30 Optical Drive Replacement, Optical Drive: adım 2, 1 resimden 1.
    • Locate the 4.8mm Phillips #0 screw on the far left of the ThinkPad, closest to the edge and above the battery, and unscrew it with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad T30 Optical Drive Replacement: adım 3, 2 resimden 1. IBM ThinkPad T30 Optical Drive Replacement: adım 3, 2 resimden 2.
    • On the side of the ThinkPad, locate a lock next to the optical drive. Use your fingernail to slide the lock to the right.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad T30 Optical Drive Replacement: adım 4, 2 resimden 1. IBM ThinkPad T30 Optical Drive Replacement: adım 4, 2 resimden 2.
    • Once it is unlocked, a small tab will pop out. Pull on the tab with your fingers.
    • The optical drive will easily slide out. Remove the optical drive.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Kost
271 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G20
3 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 2,378
