Giriş
Use this guide to replace your optical drive.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Flip the ThinkPad upside down with the bottom facing you.
Slide the latch on the underside of the ThinkPad to the right into the unlock position.
While holding the latch in the unlock position, lift the battery out with your other hand.
Locate the 4.8mm Phillips #0 screw on the far left of the ThinkPad, closest to the edge and above the battery, and unscrew it with a Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
