Ana içeriğe geç
IBM ThinkPad T30 RAM Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T30 RAM Replacement, Battery: adım 1, 3 resimden 1. IBM ThinkPad T30 RAM Replacement, Battery: adım 1, 3 resimden 2. IBM ThinkPad T30 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad T30 RAM Replacement, RAM: adım 2, 2 resimden 1. IBM ThinkPad T30 RAM Replacement, RAM: adım 2, 2 resimden 2.
    • Remove the 4 mm Phillips #0 screw located on the panel on the bottom right of the ThinkPad.
    • Lift up the cover and set it aside.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad T30 RAM Replacement: adım 3, 2 resimden 1. IBM ThinkPad T30 RAM Replacement: adım 3, 2 resimden 2.
    • Locate the four white tabs. There are two sets of white tabs, the top two holding the first RAM stick and the bottom holding the second RAM stick.
    • Removing one set at a time, press down on the white tabs at the same time. The RAM stick will pop out of place.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad T30 RAM Replacement: adım 4, 2 resimden 1. IBM ThinkPad T30 RAM Replacement: adım 4, 2 resimden 2.
    • Lift out the two RAM sticks.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Allie Knauer
90 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S3G20
3 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 37
Her zaman: 4,034
