Ana içeriğe geç
IBM ThinkPad T41 CPU Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T41 CPU Replacement, Keyboard: adım 1, 1 resimden 1.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    FixBot'a Sor
  2. IBM ThinkPad T41 CPU Replacement: adım 2, 1 resimden 1.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    FixBot'a Sor
  3. IBM ThinkPad T41 CPU Replacement: adım 3, 1 resimden 1.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    FixBot'a Sor
  4. IBM ThinkPad T41 CPU Replacement: adım 4, 1 resimden 1.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    FixBot'a Sor
  5. IBM ThinkPad T41 CPU Replacement, Trackpad: adım 5, 1 resimden 1.
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
    FixBot'a Sor
  6. IBM ThinkPad T41 CPU Replacement: adım 6, 1 resimden 1.
    • Unscrew the five screws that were hidden by the stickers.
    FixBot'a Sor
  7. IBM ThinkPad T41 CPU Replacement: adım 7, 1 resimden 1.
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
    FixBot'a Sor
  8. IBM ThinkPad T41 CPU Replacement: adım 8, 1 resimden 1.
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
    FixBot'a Sor
  9. IBM ThinkPad T41 CPU Replacement, Wireless Network Card: adım 9, 1 resimden 1.
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
    FixBot'a Sor
  10. IBM ThinkPad T41 CPU Replacement: adım 10, 1 resimden 1.
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
    FixBot'a Sor
  11. IBM ThinkPad T41 CPU Replacement: adım 11, 1 resimden 1.
    • Pull the wireless network card out.
    FixBot'a Sor
  12. IBM ThinkPad T41 CPU Replacement, Expansion Slot: adım 12, 1 resimden 1.
    • Remove the screw on the left hand side of the case, above the expansion slot.
    FixBot'a Sor
  13. IBM ThinkPad T41 CPU Replacement: adım 13, 2 resimden 1. IBM ThinkPad T41 CPU Replacement: adım 13, 2 resimden 2.
    • Lift the black plastic border by lifting on either side.
    • Once the sides are up, pull the border towards you and away from the screen.
    • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
    FixBot'a Sor
  14. IBM ThinkPad T41 CPU Replacement: adım 14, 1 resimden 1.
    • Pull the sheet metal cover away from slot.
    FixBot'a Sor
  15. IBM ThinkPad T41 CPU Replacement: adım 15, 1 resimden 1.
    • Lift out the expansion slot by starting at the entrance hole and pulling upward.
    • Note: Try wiggling the slot from side to side until it comes out all the way.
    FixBot'a Sor
  16. IBM ThinkPad T41 CPU Replacement, Modem: adım 16, 1 resimden 1.
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
    FixBot'a Sor
  17. IBM ThinkPad T41 CPU Replacement: adım 17, 1 resimden 1.
    • Lift the modem up, unplugging it from the motherboard as you lift.
    FixBot'a Sor
  18. IBM ThinkPad T41 CPU Replacement: adım 18, 2 resimden 1. IBM ThinkPad T41 CPU Replacement: adım 18, 2 resimden 2.
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
    FixBot'a Sor
  19. IBM ThinkPad T41 CPU Replacement, Screen: adım 19, 1 resimden 1.
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
    FixBot'a Sor
  20. IBM ThinkPad T41 CPU Replacement: adım 20, 1 resimden 1.
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
    FixBot'a Sor
  21. IBM ThinkPad T41 CPU Replacement: adım 21, 1 resimden 1.
    • Remove a single screw from the metal plate that secures the display cable.
    FixBot'a Sor
  22. IBM ThinkPad T41 CPU Replacement: adım 22, 1 resimden 1.
    • Pull the metal plate away from the display cable.
    FixBot'a Sor
  23. IBM ThinkPad T41 CPU Replacement: adım 23, 1 resimden 1.
    • Disconnect the display cable.
    FixBot'a Sor
  24. IBM ThinkPad T41 CPU Replacement: adım 24, 1 resimden 1.
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
    FixBot'a Sor
  25. IBM ThinkPad T41 CPU Replacement: adım 25, 1 resimden 1.
    • Lift out the screen.
    FixBot'a Sor
  26. IBM ThinkPad T41 CPU Replacement, Fan: adım 26, 1 resimden 1.
    • Unsnake the black cable from the black plastic frame.
    FixBot'a Sor
  27. IBM ThinkPad T41 CPU Replacement: adım 27, 1 resimden 1.
    • Remove the sheet metal piece, which was underneath the modem.
    FixBot'a Sor
  28. IBM ThinkPad T41 CPU Replacement: adım 28, 1 resimden 1.
    • Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
    FixBot'a Sor
  29. IBM ThinkPad T41 CPU Replacement: adım 29, 1 resimden 1.
    • Lift away the gray metal frame.
    FixBot'a Sor
  30. IBM ThinkPad T41 CPU Replacement: adım 30, 1 resimden 1.
    • Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
    • Remove three other screws on the other side of the covers.
    • You should have six screws in total, three of one size and three of another size.
    FixBot'a Sor
  31. IBM ThinkPad T41 CPU Replacement: adım 31, 1 resimden 1.
    • Lift out the optical bay and HDD covers.
    FixBot'a Sor
  32. IBM ThinkPad T41 CPU Replacement: adım 32, 1 resimden 1.
    • Lift out the black plastic frame.
    FixBot'a Sor
  33. IBM ThinkPad T41 CPU Replacement: adım 33, 1 resimden 1.
    • Unplug the fan from the motherboard.
    FixBot'a Sor
  34. IBM ThinkPad T41 CPU Replacement: adım 34, 1 resimden 1.
    • Remove the three screws on the fan.
    FixBot'a Sor
  35. IBM ThinkPad T41 CPU Replacement: adım 35, 1 resimden 1.
    • Lift the fan out.
    FixBot'a Sor
  36. IBM ThinkPad T41 CPU Replacement, CPU: adım 36, 1 resimden 1.
    • Turn the CPU retaining screw 90 degrees counterclockwise.
    • Carefully pull the CPU out of its socket.
    FixBot'a Sor
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Marissa Blustein
543 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G8
4 Üyeler
29 adet Kılavuz yazıldı
1Rehber Yorum
The disassembly of the machine goes way too far. Due to my experience it’s enough to remove keyboard, palm rest/ touchpad unit (only unscrew it and set a bit aside from fan) and fan (there are different versions, long/ short). Then you can exchange/ replace the CPU an reassamble all the stuff. This shortens the time needed to about 10 to 15 minutes. Don’t forget to add some thermal compound to assure heat flow between CPU and fan. I needed to replace a Banias with a Dothan CPU to have the NX CPU flag available. NX is a prereq for Windows 10.
Msu Europagii - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 87
Her zaman: 11,447
