Giriş
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its modem.
Neye ihtiyacın var
Close the screen and turn the closed laptop over.
Remove all 17 screws on the bottom of the computer.
The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
Remove the three screws holding down the modem in the upper left corner of the laptop.
Bir başkası bu kılavuzu tamamladı.
