Ana içeriğe geç
IBM ThinkPad T41 Motherboard Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T41 Motherboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad T41 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad T41 Motherboard Replacement: adım 3, 1 resimden 1.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad T41 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. IBM ThinkPad T41 Motherboard Replacement, Trackpad: adım 5, 1 resimden 1.
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
    FixBot'a Sor
    Yorum Ekle
  6. IBM ThinkPad T41 Motherboard Replacement: adım 6, 1 resimden 1.
    • Unscrew the five screws that were hidden by the stickers.
    FixBot'a Sor
    Yorum Ekle
  7. IBM ThinkPad T41 Motherboard Replacement: adım 7, 1 resimden 1.
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
    FixBot'a Sor
    Yorum Ekle
  8. IBM ThinkPad T41 Motherboard Replacement: adım 8, 1 resimden 1.
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
    FixBot'a Sor
    Yorum Ekle
  9. IBM ThinkPad T41 Motherboard Replacement, RAM: adım 9, 1 resimden 1.
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
    FixBot'a Sor
    Yorum Ekle
  10. IBM ThinkPad T41 Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift out the RAM chip.
    FixBot'a Sor
    Yorum Ekle
  11. IBM ThinkPad T41 Motherboard Replacement, Wireless Network Card: adım 11, 1 resimden 1.
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
    FixBot'a Sor
    Yorum Ekle
  12. IBM ThinkPad T41 Motherboard Replacement: adım 12, 1 resimden 1.
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
    FixBot'a Sor
    Yorum Ekle
  13. IBM ThinkPad T41 Motherboard Replacement: adım 13, 1 resimden 1.
    • Pull the wireless network card out.
    FixBot'a Sor
    Yorum Ekle
  14. IBM ThinkPad T41 Motherboard Replacement, CMOS Battery: adım 14, 1 resimden 1.
    • Lift the yellow plastic-covered battery up.
    FixBot'a Sor
    Yorum Ekle
  15. IBM ThinkPad T41 Motherboard Replacement: adım 15, 1 resimden 1.
    • Unplug the battery connector.
    FixBot'a Sor
    Yorum Ekle
  16. IBM ThinkPad T41 Motherboard Replacement, Speakers: adım 16, 1 resimden 1.
    • Lift the speakers out by starting with the left end and then unsnake the wires.
    FixBot'a Sor
    Yorum Ekle
  17. IBM ThinkPad T41 Motherboard Replacement: adım 17, 1 resimden 1.
    • Unplug the wires from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. IBM ThinkPad T41 Motherboard Replacement, Expansion Slot: adım 18, 1 resimden 1.
    • Remove the screw on the left hand side of the case, above the expansion slot.
    FixBot'a Sor
    Yorum Ekle
  19. IBM ThinkPad T41 Motherboard Replacement: adım 19, 2 resimden 1. IBM ThinkPad T41 Motherboard Replacement: adım 19, 2 resimden 2.
    • Lift the black plastic border by lifting on either side.
    • Once the sides are up, pull the border towards you and away from the screen.
    • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
    FixBot'a Sor
    Yorum Ekle
  20. IBM ThinkPad T41 Motherboard Replacement: adım 20, 1 resimden 1.
    • Pull the sheet metal cover away from slot.
    FixBot'a Sor
    Yorum Ekle
  21. IBM ThinkPad T41 Motherboard Replacement: adım 21, 1 resimden 1.
    • Lift out the expansion slot by starting at the entrance hole and pulling upward.
    • Note: Try wiggling the slot from side to side until it comes out all the way.
    FixBot'a Sor
    Yorum Ekle
  22. IBM ThinkPad T41 Motherboard Replacement, Modem: adım 22, 1 resimden 1.
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  23. IBM ThinkPad T41 Motherboard Replacement: adım 23, 1 resimden 1.
    • Lift the modem up, unplugging it from the motherboard as you lift.
    FixBot'a Sor
    Yorum Ekle
  24. IBM ThinkPad T41 Motherboard Replacement: adım 24, 2 resimden 1. IBM ThinkPad T41 Motherboard Replacement: adım 24, 2 resimden 2.
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
    FixBot'a Sor
    Yorum Ekle
  25. IBM ThinkPad T41 Motherboard Replacement, Screen: adım 25, 1 resimden 1.
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
    FixBot'a Sor
    Yorum Ekle
  26. IBM ThinkPad T41 Motherboard Replacement: adım 26, 1 resimden 1.
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
    FixBot'a Sor
    Yorum Ekle
  27. IBM ThinkPad T41 Motherboard Replacement: adım 27, 1 resimden 1.
    • Remove a single screw from the metal plate that secures the display cable.
    FixBot'a Sor
    Yorum Ekle
  28. IBM ThinkPad T41 Motherboard Replacement: adım 28, 1 resimden 1.
    • Pull the metal plate away from the display cable.
    FixBot'a Sor
    Yorum Ekle
  29. IBM ThinkPad T41 Motherboard Replacement: adım 29, 1 resimden 1.
    • Disconnect the display cable.
    FixBot'a Sor
    Yorum Ekle
  30. IBM ThinkPad T41 Motherboard Replacement: adım 30, 1 resimden 1.
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
    FixBot'a Sor
    Yorum Ekle
  31. IBM ThinkPad T41 Motherboard Replacement: adım 31, 1 resimden 1.
    • Lift out the screen.
    FixBot'a Sor
    Yorum Ekle
  32. IBM ThinkPad T41 Motherboard Replacement, Fan: adım 32, 1 resimden 1.
    • Unsnake the black cable from the black plastic frame.
    FixBot'a Sor
    Yorum Ekle
  33. IBM ThinkPad T41 Motherboard Replacement: adım 33, 1 resimden 1.
    • Remove the sheet metal piece, which was underneath the modem.
    FixBot'a Sor
    Yorum Ekle
  34. IBM ThinkPad T41 Motherboard Replacement: adım 34, 1 resimden 1.
    • Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
    FixBot'a Sor
    Yorum Ekle
  35. IBM ThinkPad T41 Motherboard Replacement: adım 35, 1 resimden 1.
    • Lift away the gray metal frame.
    FixBot'a Sor
    Yorum Ekle
  36. IBM ThinkPad T41 Motherboard Replacement: adım 36, 1 resimden 1.
    • Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
    • Remove three other screws on the other side of the covers.
    • You should have six screws in total, three of one size and three of another size.
    FixBot'a Sor
    Yorum Ekle
  37. IBM ThinkPad T41 Motherboard Replacement: adım 37, 1 resimden 1.
    • Lift out the optical bay and HDD covers.
    FixBot'a Sor
    Yorum Ekle
  38. IBM ThinkPad T41 Motherboard Replacement: adım 38, 1 resimden 1.
    • Lift out the black plastic frame.
    FixBot'a Sor
    Yorum Ekle
  39. IBM ThinkPad T41 Motherboard Replacement: adım 39, 1 resimden 1.
    • Unplug the fan from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  40. IBM ThinkPad T41 Motherboard Replacement: adım 40, 1 resimden 1.
    • Remove the three screws on the fan.
    FixBot'a Sor
    Yorum Ekle
  41. IBM ThinkPad T41 Motherboard Replacement: adım 41, 1 resimden 1.
    • Lift the fan out.
    FixBot'a Sor
    Yorum Ekle
  42. IBM ThinkPad T41 Motherboard Replacement, CPU: adım 42, 1 resimden 1.
    • Turn the CPU retaining screw 90 degrees counterclockwise.
    • Carefully pull the CPU out of its socket.
    FixBot'a Sor
    Yorum Ekle
  43. IBM ThinkPad T41 Motherboard Replacement, Motherboard: adım 43, 1 resimden 1.
    • Remove the two screws in the upper right corner that secure the gray metal frame.
    FixBot'a Sor
    Yorum Ekle
  44. IBM ThinkPad T41 Motherboard Replacement: adım 44, 1 resimden 1.
    • Unplug the small ribbon cable attached to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  45. IBM ThinkPad T41 Motherboard Replacement: adım 45, 1 resimden 1.
    • Remove the single screw located next to the USB slots.
    FixBot'a Sor
    Yorum Ekle
  46. IBM ThinkPad T41 Motherboard Replacement: adım 46, 1 resimden 1.
    • Rotate the device so that the front faces you.
    • Lift the entire motherboard assembly out of the case.
    FixBot'a Sor
    Yorum Ekle
  47. IBM ThinkPad T41 Motherboard Replacement: adım 47, 1 resimden 1.
    • Disconnect the power connector from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  48. IBM ThinkPad T41 Motherboard Replacement: adım 48, 1 resimden 1.
    • Using a nut driver or a pair of thin nose pliers, remove the two stand off screws next to the pink parallel port on the back of the computer.
    FixBot'a Sor
    Yorum Ekle
  49. IBM ThinkPad T41 Motherboard Replacement: adım 49, 1 resimden 1.
    • Lift up the outer end of the grey metal frame.
    • Carefully rotate the frame clockwise to release it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Marissa Blustein
543 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G8
4 Üyeler
29 adet Kılavuz yazıldı
6Kılavuz Yorumları
Hello,
Thanks for this !
When assembling again, I noticed that at the contact between the micro-processor and the cooler the thermal paste there was a very small amount of thermal paste.
I had none to add, therefore I reassembled as is.
After starting the machine again I note that the cooling fan never stops.
I suggest that at reassembling should thermal paste added.
Philippe - Yanıt Paylaş
ibm thinkpad t42 laptop driver are not download please sir my laptop motherboard information send in my email id . how can download driver download for ibm laptop
Himanshu Kumar - Yanıt Paylaş
Excellent tutorial. Thank you.
genese_cranford - Yanıt Paylaş
thanks alot!
Geburtswehe - Yanıt Paylaş
It’s tempting to try, but I’d feel much braver with a reassembly tutorial!
Christine Segatti - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 74
Her zaman: 51,271
