Ana içeriğe geç
IBM ThinkPad T41 RAM Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T41 RAM Replacement, Keyboard: adım 1, 1 resimden 1.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad T41 RAM Replacement: adım 2, 1 resimden 1.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad T41 RAM Replacement: adım 3, 1 resimden 1.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad T41 RAM Replacement: adım 4, 1 resimden 1.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. IBM ThinkPad T41 RAM Replacement, RAM: adım 5, 1 resimden 1.
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
    FixBot'a Sor
    Yorum Ekle
  6. IBM ThinkPad T41 RAM Replacement: adım 6, 1 resimden 1.
    • Lift out the RAM chip.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Marissa Blustein
543 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G8
4 Üyeler
29 adet Kılavuz yazıldı
1Rehber Yorum
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
Gary Thurman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 8,167
