Ana içeriğe geç
IBM ThinkPad T41 Screen Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T41 Screen Replacement, Keyboard: adım 1, 1 resimden 1.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad T41 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad T41 Screen Replacement: adım 3, 1 resimden 1.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
    FixBot'a Sor
    Yorum Ekle
  4. IBM ThinkPad T41 Screen Replacement: adım 4, 1 resimden 1.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. IBM ThinkPad T41 Screen Replacement, Trackpad: adım 5, 1 resimden 1.
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
    FixBot'a Sor
    Yorum Ekle
  6. IBM ThinkPad T41 Screen Replacement: adım 6, 1 resimden 1.
    • Unscrew the five screws that were hidden by the stickers.
    FixBot'a Sor
    Yorum Ekle
  7. IBM ThinkPad T41 Screen Replacement: adım 7, 1 resimden 1.
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
    FixBot'a Sor
    Yorum Ekle
  8. IBM ThinkPad T41 Screen Replacement: adım 8, 1 resimden 1.
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
    FixBot'a Sor
    Yorum Ekle
  9. IBM ThinkPad T41 Screen Replacement, Wireless Network Card: adım 9, 1 resimden 1.
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
    FixBot'a Sor
    Yorum Ekle
  10. IBM ThinkPad T41 Screen Replacement: adım 10, 1 resimden 1.
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
    FixBot'a Sor
    Yorum Ekle
  11. IBM ThinkPad T41 Screen Replacement: adım 11, 1 resimden 1.
    • Pull the wireless network card out.
    FixBot'a Sor
    Yorum Ekle
  12. IBM ThinkPad T41 Screen Replacement, Screen: adım 12, 1 resimden 1.
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
    FixBot'a Sor
    Yorum Ekle
  13. IBM ThinkPad T41 Screen Replacement: adım 13, 1 resimden 1.
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
    FixBot'a Sor
    Yorum Ekle
  14. IBM ThinkPad T41 Screen Replacement: adım 14, 1 resimden 1.
    • Remove a single screw from the metal plate that secures the display cable.
    FixBot'a Sor
    Yorum Ekle
  15. IBM ThinkPad T41 Screen Replacement: adım 15, 1 resimden 1.
    • Pull the metal plate away from the display cable.
    FixBot'a Sor
    Yorum Ekle
  16. IBM ThinkPad T41 Screen Replacement: adım 16, 1 resimden 1.
    • Disconnect the display cable.
    FixBot'a Sor
    Yorum Ekle
  17. IBM ThinkPad T41 Screen Replacement: adım 17, 1 resimden 1.
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
    FixBot'a Sor
    Yorum Ekle
  18. IBM ThinkPad T41 Screen Replacement: adım 18, 1 resimden 1.
    • Lift out the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Marissa Blustein
543 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G8
4 Üyeler
29 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 19,188
