Giriş
Replacing the fan.
Aletler
Parçalar
Hiçbir parçaya gerek yok.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
The metal bracket will now be free to move, grasp it and remove it from the device.
Remove the small rubber piece that is covering the T42's microphone,
Unscrew the 3 screws on the copper heatsink.
Now, unplug the connection to the motherboard..
7 başka kişi bu kılavuzu tamamladı.
Bir Yorum
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
