Ana içeriğe geç
IBM ThinkPad T42 Hard Drive Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T42 Hard Drive Replacement, Battery Clips: adım 1, 1 resimden 1.
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 Hard Drive Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 Hard Drive Replacement, Hard Drive Screw: adım 3, 1 resimden 1.
    • Unscrew the single screw holding the drive cage in place.
  4. IBM ThinkPad T42 Hard Drive Replacement, Sliding Drive Out: adım 4, 1 resimden 1.
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. IBM ThinkPad T42 Hard Drive Replacement, Removal of HDD: adım 5, 1 resimden 1.
    • Pull the Hard Drive out and proceed with replacement.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Austin Kidd
317 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
35 adet Kılavuz yazıldı
Bir Yorum
Excelente guía. Gracias
Luis Aguilar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 106
Her zaman: 20,705
