Ana içeriğe geç
IBM ThinkPad T42 Keyboard and Trackpad Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Bottom cover: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Rear screws: adım 2, 1 resimden 1.
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Keyboard and Trackpad: adım 3, 1 resimden 1.
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Keyboard and Trackpad Replacement: adım 4, 2 resimden 1. IBM ThinkPad T42 Keyboard and Trackpad Replacement: adım 4, 2 resimden 2.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Austin Kidd
317 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 10,324
