Giriş
The Mini-PCI port can be accessed easily after removing the rear cover
Neye ihtiyacın var
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Flip the laptop over and open the screen to access the keyboard and trackpad.
Carefully disconnect it from the motherboard and pull it out of the device.
Bir başkası bu kılavuzu tamamladı.
