Giriş
This guide will demonstrate the removal and replacement procedures for an IBM ThinkPad T42 Modem Daughter Board.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
The metal bracket will now be free to move, grasp it and remove it from the device.
Remove the small rubber piece that is covering the T42's microphone,
The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
Bir başkası bu kılavuzu tamamladı.
