Ana içeriğe geç
IBM ThinkPad T42 RAM Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T42 RAM Replacement, Battery Clips: adım 1, 1 resimden 1.
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 RAM Replacement, Removing the Battery: adım 2, 1 resimden 1.
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Unscrew the pictured screwed holding the memory cover in place.
  4. IBM ThinkPad T42 RAM Replacement: adım 4, 1 resimden 1.
    • Pry the cover open carefully (flathead screwdriver might help)
    • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
    • Pull the stick out carefully.
    • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kevin Rehm
472 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
35 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 7,068
