Ana içeriğe geç
IBM ThinkPad T42 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: adım 1, 1 resimden 1.
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: adım 2, 1 resimden 1.
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Yanıt
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Yanıt
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: adım 3, 1 resimden 1.
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: adım 4, 2 resimden 1. IBM ThinkPad T42 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: adım 5, 1 resimden 1.
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: adım 7, 1 resimden 1.
    • Carefully pull it out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kevin Rehm
472 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G76
4 Üyeler
35 adet Kılavuz yazıldı
Bir Yorum
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 13,728
