Ana içeriğe geç
IBM ThinkPad T43 CD Drive Replacement
Neye ihtiyacın var
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: adım 1, 1 resimden 1.
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: adım 2, 1 resimden 1.
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: adım 3, 1 resimden 1.
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: adım 4, 3 resimden 1. IBM ThinkPad T43 CD Drive Replacement: adım 4, 3 resimden 2. IBM ThinkPad T43 CD Drive Replacement: adım 4, 3 resimden 3.
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: adım 5, 3 resimden 1. IBM ThinkPad T43 CD Drive Replacement: adım 5, 3 resimden 2. IBM ThinkPad T43 CD Drive Replacement: adım 5, 3 resimden 3.
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: adım 6, 2 resimden 1. IBM ThinkPad T43 CD Drive Replacement: adım 6, 2 resimden 2.
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: adım 7, 1 resimden 1.
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
Sonuç
Bir başkası bu kılavuzu tamamladı.
aLiX pIeRRe
855 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 983
