Ana içeriğe geç
IBM ThinkPad X41 Keyboard Replacement
Neye ihtiyacın var
  1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. IBM ThinkPad X41 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Slide outward to unlock and lift battery up to remove.
    • Remove battery before keyboard to avoid damage to battery.
  2. IBM ThinkPad X41 Keyboard Replacement: adım 2, 1 resimden 1.
    • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
  3. IBM ThinkPad X41 Keyboard Replacement: adım 3, 3 resimden 1. IBM ThinkPad X41 Keyboard Replacement: adım 3, 3 resimden 2. IBM ThinkPad X41 Keyboard Replacement: adım 3, 3 resimden 3.
    • Flip the laptop over once more returning it to its upright position and open laptop .
  4. IBM ThinkPad X41 Keyboard Replacement: adım 4, 2 resimden 1. IBM ThinkPad X41 Keyboard Replacement: adım 4, 2 resimden 2.
    • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
    • Push firmly upward with both thumbs. This will detach keyboard from base.
    • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
  5. IBM ThinkPad X41 Keyboard Replacement: adım 5, 2 resimden 1. IBM ThinkPad X41 Keyboard Replacement: adım 5, 2 resimden 2.
    • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
    • This step's directions are based on the angle shown .
  6. IBM ThinkPad X41 Keyboard Replacement: adım 6, 1 resimden 1.
    • Lift the entire keyboard off the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lisbeth Cisneros
131 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-4, Bruce Fall 2016 CSU Fullerton, Team 2-4, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G4
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 10
Son 30 gün: 18
Her zaman: 807
