Ana içeriğe geç
IBM ThinkPad t43 RAM Replacement
Neye ihtiyacın var
  1. IBM ThinkPad t43 RAM Replacement, RAM: adım 1, 3 resimden 1. IBM ThinkPad t43 RAM Replacement, RAM: adım 1, 3 resimden 2. IBM ThinkPad t43 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • To remove the cover, you will need to take out the single screw.
    • Unscrew until the cover comes off
    • Lift the cover from the edge and pull off
    • If the cover doesn't come right up and you have felt that you have unscrewed it, you can lift the cover and the screw will come off with it.
    FixBot'a Sor
    Yorum Ekle
  2. IBM ThinkPad t43 RAM Replacement: adım 2, 3 resimden 1. IBM ThinkPad t43 RAM Replacement: adım 2, 3 resimden 2. IBM ThinkPad t43 RAM Replacement: adım 2, 3 resimden 3.
    • Place your hands on the clips and push on them outward until the RAM pops out
    FixBot'a Sor
    Yorum Ekle
  3. IBM ThinkPad t43 RAM Replacement: adım 3, 2 resimden 1. IBM ThinkPad t43 RAM Replacement: adım 3, 2 resimden 2.
    • Place hands on the RAM and pull towards yourself
    • For replacement, follow these steps in reverse order
    • Make sure that when you put in the ram that the short side is on the right
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
aLiX pIeRRe
884 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G4
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
There are two (2) SODIM slots on the T43 - this shows the easiest slot to access. There is a second SODIM slot underneath the keyboard. You will need to remove the palm rest and keyboard to access the second SODIM slot. This is the SODIM slot that comes populated with the 512MB SODIM.
Note you can add a 2GB SODIM in one slot with the 512MB SODIM in the other for a maximum of 2.5GB.
IrishMASMS - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,825
