Ana içeriğe geç
IBM ThinkPad t43 WiFi Card Replacement
Neye ihtiyacın var
  1. IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 1. IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: adım 1, 2 resimden 2.
    • Start with the laptop with the side with the logo facing down.
    • Next you will have to remove all the screws in the red circles
    • When removing the screws try to place them in order of removal on a magnetic pad. It will help when you put them back and lowers the chance of losing them
  2. IBM ThinkPad t43 WiFi Card Replacement: adım 2, 2 resimden 1. IBM ThinkPad t43 WiFi Card Replacement: adım 2, 2 resimden 2.
    • Flip the laptop so that the logo is now facing up
    • locate the lock switch on the front right
    • Slide the switch to the right to unlock the laptop
    • Make sure to unlock the laptop before opening because the keyboard may still be attached
  3. IBM ThinkPad t43 WiFi Card Replacement: adım 3, 2 resimden 1. IBM ThinkPad t43 WiFi Card Replacement: adım 3, 2 resimden 2.
    • Lift open the laptop
    • The keyboard should be detached from the bottom part of the laptop
    • Hold the edges of the keyboard and slowly pull up until it opens
    • Do not pull off the keyboard completely because there is a ribbon cable attached
  4. IBM ThinkPad t43 WiFi Card Replacement: adım 4, 2 resimden 1. IBM ThinkPad t43 WiFi Card Replacement: adım 4, 2 resimden 2.
    • Disconnect the ribbon cable by simply lifting it up
  5. IBM ThinkPad t43 WiFi Card Replacement: adım 5, 1 resimden 1.
    • The WiFi-Card is located towards the middle bottom of the laptop
  6. IBM ThinkPad t43 WiFi Card Replacement: adım 6, 2 resimden 1. IBM ThinkPad t43 WiFi Card Replacement: adım 6, 2 resimden 2.
    • Locate the two wires connected at the top of the WiFi-Card
    • Hold the card down and use the tweezers to pinch the plug and pull up.
  7. IBM ThinkPad t43 WiFi Card Replacement: adım 7, 3 resimden 1. IBM ThinkPad t43 WiFi Card Replacement: adım 7, 3 resimden 2. IBM ThinkPad t43 WiFi Card Replacement: adım 7, 3 resimden 3.
    • Place fingers on the two clips holding the card in place
    • Pull the clips outwards until the the card pops up
    • Pull the card out by pulling out away from your body
    • To replace, follow these steps in reverse order
    • Make sure that the side with the short end is on the left when you put it back in.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
aLiX pIeRRe
855 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 üyesi
UMASSD-BERNIER-S18S6G4
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
I need to know what's role of the cables AUX and MAIN because i cut one
M a n i _001 - Yanıt
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 20
Son 30 gün: 128
Her zaman: 10,409
