Giriş
This Guide shows the how to remove and replace the WiFi Card of this device.
Neye ihtiyacın var
Start with the laptop with the side with the logo facing down.
Next you will have to remove all the screws in the red circles
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I need to know what's role of the cables AUX and MAIN because i cut one
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
