Ana içeriğe geç
IBM Thinkpad T60 Hard Drive Replacement
Neye ihtiyacın var
  1. IBM Thinkpad T60 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn the Thinkpad over so you can see the back.
    • Locate this screw in the bottom left-hand corner.
  2. IBM Thinkpad T60 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
  3. IBM Thinkpad T60 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Carefully remove the plastic piece covering the hard drive port by pulling perpendicular to the side of the laptop.
  4. IBM Thinkpad T60 Hard Drive Replacement: adım 4, 2 resimden 1. IBM Thinkpad T60 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use a small screwdriver to locate the black ribbon.
    • With the screwdriver, pull the black tab out of the slot.
  5. IBM Thinkpad T60 Hard Drive Replacement: adım 5, 2 resimden 1. IBM Thinkpad T60 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Pull gently on the black ribbon and the metal tray carrying the hard drive will slide out.
  6. IBM Thinkpad T60 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the black plastic coverings on either side of the hard drive.
    • There is not a hard drive in this example, but the process is the same regardless.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Cody Kratochvil
542 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G9
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 10,688
