Ana içeriğe geç
IBM Thinkpad T60 Palm Rest Replacement
Neye ihtiyacın var
  1. IBM Thinkpad T60 Palm Rest Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 Palm Rest Replacement: adım 2, 2 resimden 1. IBM Thinkpad T60 Palm Rest Replacement: adım 2, 2 resimden 2.
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 Palm Rest Replacement, Palm Rest: adım 3, 2 resimden 1. IBM Thinkpad T60 Palm Rest Replacement, Palm Rest: adım 3, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    The screws we need to remove all supposedly share the same pictogram imprinted on the bottom case. If this is true why have you circled the rightmost screw in the photo above? The forth pictogram is near the screw below and to the left of the circled screw?
    airshack - Yanıt
  4. IBM Thinkpad T60 Palm Rest Replacement: adım 4, 1 resimden 1.
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 Palm Rest Replacement: adım 5, 2 resimden 1. IBM Thinkpad T60 Palm Rest Replacement: adım 5, 2 resimden 2.
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
    • Detach the connector by pulling upwards on the white tab.
    Putting it back on should be covered too, as it’s really hard to get everything lined up. Would be nice for some tips on that. Took me and other experienced guy 45 minutes to get the thing back on, and have all the screws seat!
    Glenn - Yanıt
    Where in this guide does it say how much RAM is supported? Am I missing something? Looks like two slots?
    airshack - Yanıt
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Dylan Kratochvil
591 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G9
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
Needs a tutorial on how to install it. I can’t get the palmrest on correctly, I can still lift up on the palmrest and the laptop doesn’t latch properly.
Kyle Gilchrist - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 2,195
