Ana içeriğe geç
IBM Thinkpad T60 Touchpad Replacement
Neye ihtiyacın var
  1. IBM Thinkpad T60 Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    FixBot'a Sor
    Yorum Ekle
  2. IBM Thinkpad T60 Touchpad Replacement: adım 2, 2 resimden 1. IBM Thinkpad T60 Touchpad Replacement: adım 2, 2 resimden 2.
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    FixBot'a Sor
    Yorum Ekle
  3. IBM Thinkpad T60 Touchpad Replacement, Palm Rest: adım 3, 2 resimden 1. IBM Thinkpad T60 Touchpad Replacement, Palm Rest: adım 3, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. IBM Thinkpad T60 Touchpad Replacement: adım 4, 1 resimden 1.
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
    FixBot'a Sor
    Yorum Ekle
  5. IBM Thinkpad T60 Touchpad Replacement: adım 5, 2 resimden 1. IBM Thinkpad T60 Touchpad Replacement: adım 5, 2 resimden 2.
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREFUL!
    • Detach the connector by pulling upwards on the white tab.
    FixBot'a Sor
    Yorum Ekle
  6. IBM Thinkpad T60 Touchpad Replacement, Touchpad: adım 6, 1 resimden 1.
    • Turn the palm rest over to access the back of the touch pad.
    FixBot'a Sor
    Yorum Ekle
  7. IBM Thinkpad T60 Touchpad Replacement: adım 7, 1 resimden 1.
    • Using your fingers, remove the plastic film that covers the two connectors to the touchpad.
    FixBot'a Sor
    Yorum Ekle
  8. IBM Thinkpad T60 Touchpad Replacement: adım 8, 3 resimden 1. IBM Thinkpad T60 Touchpad Replacement: adım 8, 3 resimden 2. IBM Thinkpad T60 Touchpad Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Identify the connector with the black cables.
    • In order to disengage the connector, use tweezers to pull out on the two grey tabs
    • Once the grey tabs have been disengaged, use tweezers to pull on the black cables and the connector will detach from the port.
    FixBot'a Sor
    Yorum Ekle
  9. IBM Thinkpad T60 Touchpad Replacement: adım 9, 2 resimden 1. IBM Thinkpad T60 Touchpad Replacement: adım 9, 2 resimden 2.
    • Identify the connector with the orange cables.
    • In order to disengage the connector use tweezers to pull the orange cable outward.
    FixBot'a Sor
    Yorum Ekle
  10. IBM Thinkpad T60 Touchpad Replacement: adım 10, 2 resimden 1. IBM Thinkpad T60 Touchpad Replacement: adım 10, 2 resimden 2.
    • Use a #0 Phillips screwdriver to unscrew the four 3.4 mm screws circled in red.
    FixBot'a Sor
    Yorum Ekle
  11. IBM Thinkpad T60 Touchpad Replacement: adım 11, 1 resimden 1.
    • Using your fingers, remove the metal framing surrounding the touch pad by pulling upwards on each of the four corners.
    FixBot'a Sor
    Yorum Ekle
  12. IBM Thinkpad T60 Touchpad Replacement: adım 12, 1 resimden 1.
    • Remove the touch pad by lifting it out of the palm rest with your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dylan Kratochvil
663 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G9
4 Üyeler
16 adet Kılavuz yazıldı
2Kılavuz Yorumları
I bought mine used on eBay. and upgraded the HDD and RAM and it is working perfectly. But I recently noticed that the palm rest is not perfectly seated at the front edge and is raised by roughly 2mm. (⅛in.) I have tried refitting the palm rest, but it hasn’t made any different. It is possible that it was like that before I fitted the RAM and I just hadn’t notice, so it could be the result of an earlier intervention. The machine still works OK and the lid closes, so it isn’t a big deal, but it is a bit annoying that such a well engineered device doesn’t go back together exactly as it should. Any suggestions?
Mike Kearney - Yanıt Paylaş
Sort of solved it . . . . . Get the left hand side located first and jiggle it about a bit and the palm rest will fit back neatly. But it isn’t immediately obvious how you shouls go about this.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 47
Her zaman: 4,390
