Parçalar
Hiçbir parçaya gerek yok.
  1. Turn the computer over so that the back is facing upwards.
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. Using a #0 Phillips screwdriver, remove the 17 mm screw.
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Carefully remove the plastic piece covering the hard drive by first pulling up then away  from the computer.
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  5. Locate the folded black tab within the hard drive port. With a screwdriver, pull the black tab out of the slot.
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  6. Pull gently on the black tab and the metal tray holding the hard drive will slide out. Pull gently on the black tab and the metal tray holding the hard drive will slide out.
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  7. Remove the plastic coverings on both sides of the hard drive.
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Kyle
317 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 8-58, Johann Spring 2013 Cal Poly, Team 8-58, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G58
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 11
Son 30 Gün: 48
Her zaman: 3,538
