Ana içeriğe geç
IBM Thinkpad T61 RAM Replacement
Neye ihtiyacın var
  1. IBM Thinkpad T61 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. IBM Thinkpad T61 RAM Replacement: adım 2, 1 resimden 1.
    • Use your finger to slide the release tab to the unlocked symbol.
  3. IBM Thinkpad T61 RAM Replacement: adım 3, 3 resimden 1. IBM Thinkpad T61 RAM Replacement: adım 3, 3 resimden 2. IBM Thinkpad T61 RAM Replacement: adım 3, 3 resimden 3.
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. IBM Thinkpad T61 RAM Replacement: adım 4, 1 resimden 1.
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
  5. IBM Thinkpad T61 RAM Replacement, RAM: adım 5, 1 resimden 1.
    • Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
    • These screws have a RAM symbol next to them.
  6. IBM Thinkpad T61 RAM Replacement: adım 6, 1 resimden 1.
    • Flip back over and open the laptop.
    • Lift up on the inside front panel just below the edge of the keyboard.
  7. IBM Thinkpad T61 RAM Replacement: adım 7, 1 resimden 1.
    • The green rectangles under the front panel are the RAM.
  8. IBM Thinkpad T61 RAM Replacement: adım 8, 3 resimden 1. IBM Thinkpad T61 RAM Replacement: adım 8, 3 resimden 2. IBM Thinkpad T61 RAM Replacement: adım 8, 3 resimden 3.
    • Press out on the two tabs on either side of the ram at the same time.
    • The RAM will release and pop up at a 25 degree angle.
  9. IBM Thinkpad T61 RAM Replacement: adım 9, 1 resimden 1.
    • Pull the RAM away from the housing to remove.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Kyle
458 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-58, Johann Spring 2013 Cal Poly, Team 8-58, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G58
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 9,422
