Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Ensure the laptop has been properly shut down and unplugged.
Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
Use your finger to slide the release tab to the unlocked symbol.
Hold the tab in the unlocked position and push the battery away from the computer to remove it.
Slide the new battery in until it clicks.
Ensure that the release tab is in the locked position.
Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
Flip back over and open the laptop.
Lift up on the inside front panel just below the edge of the keyboard.
The green rectangles under the front panel are the RAM.
Press out on the two tabs on either side of the ram at the same time.
The RAM will release and pop up at a 25 degree angle.
15 farklı kişi bu kılavuzu tamamladı.
