Ana içeriğe geç
IBM Thinkpad T61 Trackpad Replacement
Neye ihtiyacın var
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: adım 2, 1 resimden 1.
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: adım 3, 2 resimden 1. IBM Thinkpad T61 Trackpad Replacement: adım 3, 2 resimden 2.
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: adım 4, 3 resimden 1. IBM Thinkpad T61 Trackpad Replacement: adım 4, 3 resimden 2. IBM Thinkpad T61 Trackpad Replacement: adım 4, 3 resimden 3.
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: adım 5, 1 resimden 1.
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: adım 6, 1 resimden 1.
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: adım 7, 2 resimden 1. IBM Thinkpad T61 Trackpad Replacement: adım 7, 2 resimden 2.
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
Sonuç
Replace the battery and plug in your computer. Test out your new trackpad!
6 farklı kişi bu kılavuzu tamamladı.
Raymond Lawton
245 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S6G6
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,910
