Ana içeriğe geç
IKEA KOPPLA Connector (fix)
Neye ihtiyacın var
  1. IKEA KOPPLA Connector (fix), break open the adapter: adım 1, 3 resimden 1. IKEA KOPPLA Connector (fix), break open the adapter: adım 1, 3 resimden 2. IKEA KOPPLA Connector (fix), break open the adapter: adım 1, 3 resimden 3.
    • open device , using brute force is the only option because it's ultrasonic welded together.
    • use screw driver or squeeze in a vice to crack it open.''
  2. IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): adım 2, 2 resimden 1. IKEA KOPPLA Connector (fix), Fixing the issue (broken solderpoints): adım 2, 2 resimden 2.
    • Resolder all the USB connector pins (red box'es), on all 3 USB connectors to be sure they are functional. (on this image the top one is defective)
    • The reason solder points break is the connector support is soldered onto the board on one side only. Not by the arrow. Thereby adding stress directly to the soldered pins.
    • In addition the connector pin (square) near the U2 marking is too short and therefore may not be soldered properly.
    • see 2nd image for example of front support pin is pulled out of solder area.
  3. IKEA KOPPLA Connector (fix), add glue to connectors: adım 3, 2 resimden 1. IKEA KOPPLA Connector (fix), add glue to connectors: adım 3, 2 resimden 2.
    • add hot melt glue in these areas on the board and on the side of the connector.
    • Add the cover first to understand where there is room for it in the cover.
    • If connector is not glued, it is likely the charger will stop working again in the near future.
    • Ikea have been notified of this issue.
    • To seal the enclosure , add suitable glue to edge, and press the top/bottom together.
    • Use as vice while holding them together, while the glue hardens.
Sonuç
I understand these adapters are cheap, but they can be repaired as described.
4 farklı kişi bu kılavuzu tamamladı.
Carsten Dahl Hjarup
2.718 İtibar
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 74
Her zaman: 2,227
