Ana içeriğe geç
ILVE Microwave Replacement Bulb Replacement
Neye ihtiyacın var
  1. ILVE Microwave  Replacement Bulb Replacement, Remove the microwave from cabinate: adım 1, 1 resimden 1.
    • Remove the brown plug.
    • The screw attaching the microwave is below
    FixBot'a Sor
    Yorum Ekle
  2. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: adım 2, 2 resimden 1. ILVE Microwave  Replacement Bulb Replacement, Remove the outer case: adım 2, 2 resimden 2.
    • Remove the cross point screws from the outer case back
    • One screw has a tamper proof head so cut a slot it in and unscrew with a flat head screw driver.
    • Take caution to ensure that no metal shards fall inside the microwave. You may want to tape over the holes or wipe the area off with a damp cloth or paper towel once finished.
    FixBot'a Sor
    Yorum Ekle
  3. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb socket: adım 3, 1 resimden 1.
    • The socket is on top right side of the microwave
    • Remove the plugs
    • Bend up the metal clips, and pull out the socket
    FixBot'a Sor
    Yorum Ekle
  4. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: adım 4, 2 resimden 1. ILVE Microwave  Replacement Bulb Replacement, Remove the bulb from the socket: adım 4, 2 resimden 2.
    • Remove the white glue (or sealer) that's around the bulb screw using a small screw driver.
    • The glue goes all the way down the thread so remove as much as you can see.
    • Use leather gloves to unscrew in case the bulb breaks. It needs quite a lot of force so make sure you've got every bit of glue out.
    FixBot'a Sor
    Yorum Ekle
  5. ILVE Microwave  Replacement Bulb Replacement, Re assmeble: adım 5, 1 resimden 1.
    • When you re assemble the outer case make sure the tabs on the front go either side of the front.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Martin Hampton
1.350 İtibar
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 66
Her zaman: 4,429
