Giriş
Follow these instructions to remove and replace a potentiometer on your guitar.
  1. Gently place the instrument upside-down on a soft surface.
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
    • Use a phillips head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. Remove the cap by lifting upwards to reveal the battery. Remove the cap by lifting upwards to reveal the battery.
    • Remove the cap by lifting upwards to reveal the battery.
  4. Gently lift the battery from the cavity. Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery. Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
  5. Locate back plate cap and screws.
    • Locate back plate cap and screws.
  6. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  7. Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise. Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise.
    • Use a phillips head screwdriver to remove the four screws,#1-1mm, by turning the screws counter-clockwise.
  8. Remove cap by lifting upwards, revealing the circuitry of the instrument. Remove cap by lifting upwards, revealing the circuitry of the instrument.
    • Remove cap by lifting upwards, revealing the circuitry of the instrument.
  9. Turn the instrument over. Locate the potentiometer knob.
    • Turn the instrument over.
    • Locate the potentiometer knob.
    • Locate the allen screw socket on the knob.
  10. Use a 1/16" allen wrench to loosen the allen screw. After the screw is loosened, lift the knob off of the instrument.
    • Use a 1/16" allen wrench to loosen the allen screw.
    • After the screw is loosened, lift the knob off of the instrument.
  11. Locate the potentiometer nut, at the base of the potentiometer piston. Use the adjustable wrench to remove the nut from the potentiometer.
    • Locate the potentiometer nut, at the base of the potentiometer piston.
    • Use the adjustable wrench to remove the nut from the potentiometer.
  12. Carefully turn the instrument over. Remove the potentiometer from the instrument by gently pulling it upward.
    • Carefully turn the instrument over.
    • Remove the potentiometer from the instrument by gently pulling it upward.
  13. Use the soldering iron to release the black, yellow, and white wires from the side of the potentiometer. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
    • Use the soldering iron to release the black, yellow, and white wires from the side of the potentiometer.
    • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
  14. Use the soldering iron to release the black and green wires from the bottom of the potentiometer. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
    • Use the soldering iron to release the black and green wires from the bottom of the potentiometer.
Sonuç
To reassemble your device, follow these instructions in reverse order with a new potentiometer.
Chris Pittner
163 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G18
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 21
Her zaman: 2,369
