Ana içeriğe geç
Ibanez 5 String Bass Model SR405QM Strings Replacement
Neye ihtiyacın var
  1. Ibanez 5 String Bass Model SR405QM Strings Replacement, Strings: adım 1, 1 resimden 1.
    • Loosen all of the strings completely by turning each tuning peg counter clockwise. Continue until there is no tension in the strings
  2. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 2, 1 resimden 1.
    • Remove each string by pulling it out of the string tree at the top and through the bridge at the bottom.
  3. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 3, 1 resimden 1.
    • Thread the largest new string through the bridge hole farthest from the knobs. Hold it firmly in place.
  4. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 4, 1 resimden 1.
    • Pull the string up to the corresponding string tree.
  5. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 5, 1 resimden 1.
    • Firmly grasp the middle of the string and pull it taut.
  6. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 6, 2 resimden 1. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 6, 2 resimden 2.
    • On a taut string, measure one inch past the nut before using a pair of wire cutters to cut the string.
  7. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 7, 1 resimden 1.
    • Take the end of the string and insert it into the hole in the middle of the string tree.
  8. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 8, 1 resimden 1.
    • Bend the string sideways into the channel of the string tree.
  9. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 9, 1 resimden 1.
    • Use one hand to maintain tension in the string by grabbing the string and rotating the hand toward the fret board.
    • If tension is not retained it may result in uneven tension in the string tree, causing the tree to break.
  10. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 10, 1 resimden 1.
    • Rotate the tuning peg counterclockwise until the string is slightly taut, but not tight.
    • Check to ensure that the string is lined up with the proper notch in the nut.
    • You will have proper alignment when the sting bends at a minimum angle.
  11. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 11, 1 resimden 1.
    • Repeat steps 3-10 for each string.
    • Each string will progressively get closer to the knobs. It is not essential to progress from thick to thin strings, but it is important that they are connected to the proper string tree.
  12. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 12, 1 resimden 1.
    • Caution: Do not over tighten the strings. This can cause the strings to snap and could cause bodily injury. The strings are too tight when you have difficulty turning the tuning peg.
    • Tighten the string until it is close to the proper tuning. Use an electronic tuner or an online tuner that uses your computer's microphone. (Google: Online Tuner)
    • Note: Clockwise rotation of the tuning peg tightens the string and produces a higher pitch. Counter-clockwise rotation loosens the string causing a lower pitch.
    • Tune the thickest string to B, the second thickest string E, the next thickest to A, the next string to D, and the last string to G.
  13. Ibanez 5 String Bass Model SR405QM Strings Replacement: adım 13, 1 resimden 1.
    • Because the strings will change pitch as the guitar body deforms due to increased tension, repeat step 12 after each string is tuned individually.
Sonuç
You have successfully replaced and tuned your strings!
2 farklı kişi bu kılavuzu tamamladı.
Vincent Nguyen
82 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G18
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Thanks for this, it's very helpful! However, I've always changed strings one at a time for two reasons - 1)keeping the tension on the neck is better than relieving it all at once, and 2) it's easier to tune the string. I usually start with the 1st string (lightest) and work my way up.
fisheromen308 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 2,826
