Ana içeriğe geç
Ibanez V300 Guitar Strings Replacement
Neye ihtiyacın var
  1. Ibanez V300 Guitar Strings Replacement, Loosening the Old String: adım 1, 1 resimden 1.
    • Turn the peg in the direction of less resistance. The string should become more slacked or droopy.
  2. Ibanez V300 Guitar Strings Replacement, Removing the Old String from the Head: adım 2, 1 resimden 1.
    • When the string is very loose and is no longer coiled around the peg, slide it through the hole in the peg to remove it from the head.
  3. Ibanez V300 Guitar Strings Replacement, Removing the Bridge Pin: adım 3, 1 resimden 1.
    • Using the all-in-one tool, slide the peg between the groove and gently lift up until the peg comes out.
  4. Ibanez V300 Guitar Strings Replacement, Aligning the String With the Bridge Pin: adım 4, 2 resimden 1. Ibanez V300 Guitar Strings Replacement, Aligning the String With the Bridge Pin: adım 4, 2 resimden 2.
    • With your new string, align the nut end with the groove in the bridge pin so that the nut is at the opposite side of the head of the pin.
  5. Ibanez V300 Guitar Strings Replacement, Replacing the Bridge Pin: adım 5, 2 resimden 1. Ibanez V300 Guitar Strings Replacement, Replacing the Bridge Pin: adım 5, 2 resimden 2.
    • Slide both the string and the bridge pin back into the hole,(make sure the groove is facing the string) and then when in place, apply a small amount of force with your thumb until you hear it click into place.
  6. Ibanez V300 Guitar Strings Replacement, Replacing the New String at the Head: adım 6, 1 resimden 1.
    • Thread the end of the new string through the hole of the peg, but don't pull it all the way tight, leave the string loose on the neck.
  7. Ibanez V300 Guitar Strings Replacement, Tightening the New String: adım 7, 3 resimden 1. Ibanez V300 Guitar Strings Replacement, Tightening the New String: adım 7, 3 resimden 2. Ibanez V300 Guitar Strings Replacement, Tightening the New String: adım 7, 3 resimden 3.
    • With the new string loose on the neck, tighten the peg so the string winds in the same direction as the other strings and wind it until it is tight and does not wobble. Make sure the string is aligned with the groove in the neck.
  8. Ibanez V300 Guitar Strings Replacement, Removing Excess Length: adım 8, 1 resimden 1.
    • Using guitar string cutters, leave between a quarter inch to half of an inch of string so the excess string does not get in the way.
Sonuç
Follow the instructions for any broken or dull strings that need replacing.
Bir başkası bu kılavuzu tamamladı.
Kevin Petri
168 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-26, Donnelly Fall 2014 USF Tampa, Team 1-26, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G26
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 963
