Ana içeriğe geç
IdeaPad Yoga 13 Charging Port Replacement
Neye ihtiyacın var
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: adım 1, 1 resimden 1.
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: adım 2, 2 resimden 1. IdeaPad Yoga 13 Charging Port Replacement: adım 2, 2 resimden 2.
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: adım 3, 1 resimden 1.
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: adım 4, 2 resimden 1. IdeaPad Yoga 13 Charging Port Replacement: adım 4, 2 resimden 2.
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: adım 5, 1 resimden 1.
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: adım 6, 3 resimden 1. IdeaPad Yoga 13 Charging Port Replacement: adım 6, 3 resimden 2. IdeaPad Yoga 13 Charging Port Replacement: adım 6, 3 resimden 3.
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kaitlyn Johnson
157 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Harley Spring 2019 IUPUI, Team S1-G2, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G2
3 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
do you have the schematic of the board?
Jorge Herrera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 1,603
