Giriş
The keyboard bezel is part of the chassis that protects your laptop’s interior components. Cosmetic damage may be unsightly, but doesn’t affect your laptop’s functionality. You may need to remove the keyboard bezel to access interior components.
Parçalar
Hiçbir parça belirtilmedi.
Locate the ribbon cable connecting the keyboard to the motherboard.
Use the tip of the opening tool to lift the black flap on the connector.
With the twezers, gently lift the ribbon cable out of the connector.
Ensure the cutouts on the end of the cable match the tabs on the connector.
Locate and remove the screws holding the bezel to the laptop body:
Two 3 mm Phillips screws
Three 5.5 mm Phillips screws
4 farklı kişi bu kılavuzu tamamladı.
