Ana içeriğe geç
Igloo Mini Fridge IRF32BK Compressor Relay Replacement
Neye ihtiyacın var
  1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: adım 1, 3 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: adım 1, 3 resimden 2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement, Compressor Relay: adım 1, 3 resimden 3.
    • Clear out all food products in the refrigerator.
    • Unplug the plug from the outlet.
    • Turn the refrigerator backward.
    • Don't turn the mini fridge on its side. Doing so will ruin the mini fridge gas.
  2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 2, 3 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 2, 3 resimden 2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 2, 3 resimden 3.
    • Use a knife to cut the plastic holding strips.
    • Don't damage the rubber covering. Damaging it can be dangerous when turning the mini fridge back on.
  3. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 3, 2 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 3, 2 resimden 2.
    • Use your thumbs to open the rubber covering.
  4. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 4, 3 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 4, 3 resimden 2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 4, 3 resimden 3.
    • Use the CR-V screwdriver to unscrew the screw by rotating the screwdriver counter clockwise.
  5. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 5, 2 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 5, 2 resimden 2.
    • Push the flathead screwdriver upward to pry open the metal hinge.
    • Repeat this same step on the other side.
  6. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 6, 2 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 6, 2 resimden 2.
    • Remove the plastic box by pulling it away from the wires.
  7. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 7, 1 resimden 1.
    • Stick the flathead screwdriver in between the compressor relay and the pot.
    • Wiggle the screwdriver left to right five times.
    • Use your hand to pull the compressor relay from the pot.
  8. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 8, 1 resimden 1.
    • Use the flathead screwdriver to push the white cable against the compressor relay to disconnect it.
  9. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 9, 1 resimden 1.
    • Connect the white cable to the new compressor relay.
    • You should hear a click when you connect it correctly.
  10. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 10, 2 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 10, 2 resimden 2.
    • Connect the holes on the compressor relay to the pot.
    • Connect the top hole on the white part of the compressor relay first, then connect the rest of the holes.
  11. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 11, 3 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 11, 3 resimden 2. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 11, 3 resimden 3.
    • Hold the plastic box as shown in the picture and put it on the compressor relay.
    • Reattach the metal hinge back onto the plastic box.
    • You should hear a click when putting back on the metal hinge.
    • These two steps must be done at the same time in order to work.
  12. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 12, 1 resimden 1.
    • Reattach the screw to the green wire and use the CR-V screwdriver to reinsert the screw.
    • Refer back to Step 4 to help you complete this step.
  13. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 13, 2 resimden 1. Igloo Mini Fridge IRF32BK Compressor Relay Replacement: adım 13, 2 resimden 2.
    • Warp the rubber coating back onto the metal wire.
    • Warp the new plastic holding stripes onto the rubber coating.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Rizwan Laghari
217 İtibar
1 Kılavuz yazıldı
3 Yorum
Would you happen to know the part numbers for the start relay and overload on this mini fridge that you are working on in this tutorial?
chrisalexandre - Yanıt
Hi, I have a question?? Does the Igloo irf32bk have a "linear compressor" ?
bruce o - Yanıt
re-try post! ok,here goes.....does the Igloo IRF32BK operate with a "linear" compressor?
bruce o - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 69
Son 30 gün: 476
Her zaman: 9,940
