Giriş
This guide will show you how to reattach the legs of an Ikea RESGODS model bed tray or serving tray. The frequent use of a bed tray can loosen the screws or, in my case, the screws are totally detached from the legs. Replacing a bed tray can cost as much as twenty-dollars to forty-dollars, depending on the brand. This guide will show the detailed steps to fix the RESGODS bed tray from Ikea.
Neye ihtiyacın var
Carefully place the bed tray face down on an even surface.
In conclusion, this guide is generally easy. You will just need the right screws and steel flat washer to fix it.
Bir başkası bu kılavuzu tamamladı.
