Ana içeriğe geç
Ilco Orion Key Machine deburring wheel replacement
Neye ihtiyacın var
  1. Ilco Orion Key Machine deburring wheel replacement, deburring wheel: adım 1, 1 resimden 1.
    • As you can see, the deburring wheel on this machine is quite worn down. Time to replace!
  2. Ilco Orion Key Machine deburring wheel replacement: adım 2, 1 resimden 1.
    • Using an M6 allen wrench (circled in red), remove the old wheel.
    • Use another allen wrench, strategically placed in a hole next to the cutting wheel, to provide torque in the clockwise direction. The size of the wrench does not matter, so long as it fits reasonably within the hole. This is to prevent the whole assembly from turning while loosening the bolt that holds the wheel in place.
  3. Ilco Orion Key Machine deburring wheel replacement: adım 3, 1 resimden 1.
    • Add washers, as necessary, and replace the wheel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jerry Orr
920 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,688
