Aletler
Parçalar
Hiçbir parça belirtilmedi.
Flip the device over so the bottom is facing up.
You will know it is the bottom because there will be six silver screws visible.
Flip the disk drive over so the the plug on the daughter board is visible.
Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
Remove the small spring that connects the plastic arm to the disk drive.
To the keep the spring from flying in the air and getting lost, put your finger on one end of the spring to hold it in place while you detach the other end. It does not matter which end you chose to detach first.
