Ana içeriğe geç
Imation Superdisk USB Drive Plastic Housing Replacement
Neye ihtiyacın var
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: adım 1, 2 resimden 1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: adım 1, 2 resimden 2.
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: adım 2, 2 resimden 1. Imation Superdisk USB Drive Plastic Housing Replacement: adım 2, 2 resimden 2.
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: adım 3, 2 resimden 1. Imation Superdisk USB Drive Plastic Housing Replacement: adım 3, 2 resimden 2.
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: adım 4, 2 resimden 1. Imation Superdisk USB Drive Plastic Housing Replacement: adım 4, 2 resimden 2.
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: adım 5, 2 resimden 1. Imation Superdisk USB Drive Plastic Housing Replacement: adım 5, 2 resimden 2.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: adım 6, 2 resimden 1. Imation Superdisk USB Drive Plastic Housing Replacement: adım 6, 2 resimden 2.
    • Slide the metal housing out of the plastic shell.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caitlin Horwatt
137 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G2
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 835
