Ana içeriğe geç
Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755
Neye ihtiyacın var
  1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755, Impeller Thrust Washers: adım 1, 2 resimden 1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755, Impeller Thrust Washers: adım 1, 2 resimden 2.
    • Remove the eight 3.5 cm M4 hex screws securing the pump to the shroud.
  2. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 2, 2 resimden 1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 2, 2 resimden 2.
    • Remove the tension ring and separate the pump from the shroud.
  3. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 3, 3 resimden 1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 3, 3 resimden 2. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 3, 3 resimden 3.
    • Gently wiggle the 2.5 mm flat head screw driver in between the divide of the keeper washer.
    • Slowly raise one side of the keeper washer above the top of the ceramic shaft.
    • Place the flat head screw driver under the opposite side of the keeper washer and pop it off the shaft.
    • Bending the keeper washer too far can break it. Be gentle when performing this step.
  4. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 4, 3 resimden 1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 4, 3 resimden 2. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 4, 3 resimden 3.
    • Remove the white keeper washer and the black upper thrust washer.
    • Seperate the impeller from the pump body.
    • Expect resistance when separating the impeller as a magnet is holding it down.
  5. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 5, 1 resimden 1.
    • Remove the black lower thrust washer to complete the disassembly.
  6. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 6, 1 resimden 1.
    • Install the first new thrust washer to the bottom of the ceramic shaft.
  7. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 7, 1 resimden 1.
    • Install the impeller back onto the ceramic shaft on top of the bottom thrust washer.
  8. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 8, 1 resimden 1.
    • Install the new top thrust washer onto the ceramic shaft.
  9. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 9, 3 resimden 1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 9, 3 resimden 2. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 9, 3 resimden 3.
    • Place the keeper washer on the tip of the ceramic shaft.
    • Use the flat head screw driver and the hex wrench to push both sides of the keeper washer down until it reseats itself on the shaft.
  10. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 10, 2 resimden 1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 10, 2 resimden 2.
    • Place the pump into the bottom of the shroud and reposition the tension ring.
  11. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: adım 11, 1 resimden 1.
    • Screw in the eight 3.5 cm M4 hex screws to complete the reassembly.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Robert Hladun
243 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Size of the washer?
tuo-liu - Yanıt
Information : this tutorial is related to a specific water cooling pump (Alphacool Eispumpe) used in some custom desktop computers.
Brendan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 1,989
