Ana içeriğe geç
Impression i7 Battery Replacement
Neye ihtiyacın var
    1. Impression i7 Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Impression i7 Battery Replacement: adım 2, 1 resimden 1.
      • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
      FixBot'a Sor
      Yorum Ekle
    3. Impression i7 Battery Replacement: adım 3, 1 resimden 1.
      • After the entire perimeter has been pried, remove the back of the device.
      • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
      FixBot'a Sor
      Yorum Ekle
    4. Impression i7 Battery Replacement: adım 4, 2 resimden 1. Impression i7 Battery Replacement: adım 4, 2 resimden 2.
      • Remove the transparent, orange tape from the edge of the battery.
      • Pry the battery off, using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    5. Impression i7 Battery Replacement: adım 5, 1 resimden 1.
      • Desolder the positive and negative leads.
      FixBot'a Sor
      Yorum Ekle
    6. Impression i7 Battery Replacement: adım 6, 2 resimden 1. Impression i7 Battery Replacement: adım 6, 2 resimden 2.
      • Pull the battery away from the adhesive.
      • Peel the gray tape from the top of the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cole Beaver
417 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Baechle Fall 2018 IUPUI, Team S1-G5, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 514
