Ana içeriğe geç
Impression i7 USB Port Replacement
Neye ihtiyacın var
  1. Impression i7 USB Port Replacement, Battery: adım 1, 1 resimden 1.
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 USB Port Replacement: adım 2, 1 resimden 1.
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 USB Port Replacement: adım 3, 1 resimden 1.
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 USB Port Replacement: adım 4, 2 resimden 1. Impression i7 USB Port Replacement: adım 4, 2 resimden 2.
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 USB Port Replacement: adım 5, 1 resimden 1.
    • Desolder the positive and negative leads.
  6. Impression i7 USB Port Replacement: adım 6, 2 resimden 1. Impression i7 USB Port Replacement: adım 6, 2 resimden 2.
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 USB Port Replacement, USB Port: adım 7, 1 resimden 1.
    • Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
  8. Impression i7 USB Port Replacement: adım 8, 2 resimden 1. Impression i7 USB Port Replacement: adım 8, 2 resimden 2.
    • Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
  9. Impression i7 USB Port Replacement: adım 9, 2 resimden 1. Impression i7 USB Port Replacement: adım 9, 2 resimden 2.
    • Desolder the eight solder joints holding the USB Port in place.
Sonuç
Cole Beaver
390 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Baechle Fall 2018 IUPUI, Team S1-G5, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 166
