Giriş
This is a general guide of how to take an In-ground pool filter out of the pump, clean it and return it back into the pump.
Neye ihtiyacın var
While the filter housing is apart, you should inspect the O-ring to determine if it has any cracks or tears. If so, replace it with a new O-ring. If it still appears to be in decent condition, then continue to use it and apply a little lube. NEVER use Vaseline or any other petroleum-based lubricant on pool parts. Look for silicone-based lubes.
Every pool has different size filters. This guide is a general reference of how to replace a filter and return the filter back to the pump. To reassemble your device, follow these instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
