Ana içeriğe geç
In-Ground Pool Filter Replacement
Neye ihtiyacın var
  1. In-Ground Pool Filter Replacement, Filter: adım 1, 2 resimden 1. In-Ground Pool Filter Replacement, Filter: adım 1, 2 resimden 2.
    • Make sure the pool pump switch is off.
    FixBot'a Sor
    Yorum Ekle
  2. In-Ground Pool Filter Replacement: adım 2, 3 resimden 1. In-Ground Pool Filter Replacement: adım 2, 3 resimden 2. In-Ground Pool Filter Replacement: adım 2, 3 resimden 3.
    • Unscrew the metal ring bracket that is on the filter housing in order to remove the top half of the filter housing (lid). Turn the handle in a counter-clock wise motion until it is completely loose and the screw can be removed.
    FixBot'a Sor
    Yorum Ekle
  3. In-Ground Pool Filter Replacement: adım 3, 3 resimden 1. In-Ground Pool Filter Replacement: adım 3, 3 resimden 2. In-Ground Pool Filter Replacement: adım 3, 3 resimden 3.
    • Take the metal ring bracket off.
    FixBot'a Sor
    Yorum Ekle
  4. In-Ground Pool Filter Replacement: adım 4, 2 resimden 1. In-Ground Pool Filter Replacement: adım 4, 2 resimden 2.
    • Remove the top half of the filter housing.
    FixBot'a Sor
    Yorum Ekle
  5. In-Ground Pool Filter Replacement: adım 5, 3 resimden 1. In-Ground Pool Filter Replacement: adım 5, 3 resimden 2. In-Ground Pool Filter Replacement: adım 5, 3 resimden 3.
    • Remove the O-ring.
    FixBot'a Sor
    Yorum Ekle
  6. In-Ground Pool Filter Replacement: adım 6, 3 resimden 1. In-Ground Pool Filter Replacement: adım 6, 3 resimden 2. In-Ground Pool Filter Replacement: adım 6, 3 resimden 3.
    • Unscrew the filter cap in a counter clock wise motion until it comes off.
    FixBot'a Sor
    Yorum Ekle
  7. In-Ground Pool Filter Replacement: adım 7, 3 resimden 1. In-Ground Pool Filter Replacement: adım 7, 3 resimden 2. In-Ground Pool Filter Replacement: adım 7, 3 resimden 3.
    • Take the pool filter out and place on the ground. Put the new filter in and to put it all back together you can simply follow these directions in reverse order.
    FixBot'a Sor
    Yorum Ekle
    • While the filter housing is apart, you should inspect the O-ring to determine if it has any cracks or tears. If so, replace it with a new O-ring. If it still appears to be in decent condition, then continue to use it and apply a little lube. NEVER use Vaseline or any other petroleum-based lubricant on pool parts. Look for silicone-based lubes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Every pool has different size filters. This guide is a general reference of how to replace a filter and return the filter back to the pump. To reassemble your device, follow these instructions in reverse order.
4 farklı kişi bu kılavuzu tamamladı.
Benjamin Goodman
232 İtibar
1 Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-2, Prince Fall 2016 Pasco Hernando, Team 5-2, Prince Fall 2016 üyesi
PHSC-PRINCE-F16S5G2
1 Üye
12 adet Kılavuz yazıldı
1Rehber Yorum
Which model is this?
Osvaldo walle - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 66
Her zaman: 1,352
