Neye ihtiyacın var
Carefully remove the rubber fan bumper from the edge of the heat sink.
Bu adımda kullanılan alet:Tweezers$4.99
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
One of the screws holding the top shell of the fan assembly is hidden just behind the I/O board cable.
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
3 farklı kişi bu kılavuzu tamamladı.
