Ana içeriğe geç
InFocus IN3104 Color Wheel Replacement
Neye ihtiyacın var
    1. InFocus IN3104 Color Wheel Replacement, Top Cover: adım 1, 3 resimden 1. InFocus IN3104 Color Wheel Replacement, Top Cover: adım 1, 3 resimden 2. InFocus IN3104 Color Wheel Replacement, Top Cover: adım 1, 3 resimden 3.
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus IN3104 Color Wheel Replacement: adım 2, 3 resimden 1. InFocus IN3104 Color Wheel Replacement: adım 2, 3 resimden 2. InFocus IN3104 Color Wheel Replacement: adım 2, 3 resimden 3.
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: adım 3, 2 resimden 1. InFocus IN3104 Color Wheel Replacement, InFocus IN3104 Metal Cover Disassembly: adım 3, 2 resimden 2.
      • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
      • Lift up the metal cover and set it aside to reveal the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus IN3104 Color Wheel Replacement: adım 4, 3 resimden 1. InFocus IN3104 Color Wheel Replacement: adım 4, 3 resimden 2. InFocus IN3104 Color Wheel Replacement: adım 4, 3 resimden 3.
      • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
      • Pull out the blue-tipped, white ribbon cable from the connector.
      • Remove the metal cover.
      FixBot'a Sor
      Yorum Ekle
    1. InFocus IN3104 Color Wheel Replacement, Color Wheel: adım 5, 3 resimden 1. InFocus IN3104 Color Wheel Replacement, Color Wheel: adım 5, 3 resimden 2. InFocus IN3104 Color Wheel Replacement, Color Wheel: adım 5, 3 resimden 3.
      • Unplug two cables from the edge of the motherboard labeled 80.87 MO and KYO.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus IN3104 Color Wheel Replacement: adım 6, 2 resimden 1. InFocus IN3104 Color Wheel Replacement: adım 6, 2 resimden 2.
      • Carefully lift up the black paper cover. Do not completely remove it from the device.
      • Lift the paper cover up to reveal two 6mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. InFocus IN3104 Color Wheel Replacement: adım 7, 2 resimden 1. InFocus IN3104 Color Wheel Replacement: adım 7, 2 resimden 2.
      • Use a Phillips #1 screwdriver to remove the two 6mm screws.
      • Remove the color wheel from the device by lifting it out of the projector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 845
