Ana içeriğe geç
InFocus IN3104 Filter Replacement
Neye ihtiyacın var
    1. InFocus IN3104 Filter Replacement, Top Cover: adım 1, 3 resimden 1. InFocus IN3104 Filter Replacement, Top Cover: adım 1, 3 resimden 2. InFocus IN3104 Filter Replacement, Top Cover: adım 1, 3 resimden 3.
      • Turn the projector so that the lens is facing you.
      • On the left side of the projector, there is a screw and a knob inside of the small grate.
      • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
      • Remove the service cover.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus IN3104 Filter Replacement: adım 2, 3 resimden 1. InFocus IN3104 Filter Replacement: adım 2, 3 resimden 2. InFocus IN3104 Filter Replacement: adım 2, 3 resimden 3.
      • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
      • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
      • Remove the top cover.
      • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. InFocus IN3104 Filter Replacement, Filter: adım 3, 3 resimden 1. InFocus IN3104 Filter Replacement, Filter: adım 3, 3 resimden 2. InFocus IN3104 Filter Replacement, Filter: adım 3, 3 resimden 3.
      • Use a Phillips # 1 screw driver to remove the 6 mm screw that secures the filter.
      • Once the screw is removed, remove the filter by pulling it straight out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 32
Her zaman: 614
