Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This Metal Cover needs to be removed in order to replace most parts in the device.
  1. Turn the projector so that the lens is facing you. On the left side of the projector, there is a screw and a knob inside of the small grate. Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. Use a Phillips #1 screwdriver to remove the seven 6 mm screws. Use a Phillips #1 screwdriver to remove the two 5 mm screws. Remove the top cover.
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. Use a Phillips #1 screwdriver to remove the nine 6 mm screws. Lift up the metal cover and set it aside to reveal the motherboard.
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger. Pull out the blue-tipped, white ribbon cable from the connector. Remove the metal cover.
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 61
