Giriş
Use this guide to replace the top plate of the InFocus 3114.
The top plate may be cracked and need replacing, but more often, this component requires removal in order to provide access to other components of the device such as the projector, such as the lamp, fan, lens, and DMD chip.
Properly performing this step is vital in repairing other components of the device.
Neye ihtiyacın var
Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
Bir başkası bu kılavuzu tamamladı.
