Ana içeriğe geç
InFocus IN35W Fan Replacement
Neye ihtiyacın var
    1. InFocus IN35W Fan Replacement, Top Plate: adım 1, 3 resimden 1. InFocus IN35W Fan Replacement, Top Plate: adım 1, 3 resimden 2. InFocus IN35W Fan Replacement, Top Plate: adım 1, 3 resimden 3.
      • Use the plastic opening tool to remove the front plastic casing surrounding the lens.
      • Pry apart the clips securing the top and bottom of the device using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus IN35W Fan Replacement: adım 2, 2 resimden 1. InFocus IN35W Fan Replacement: adım 2, 2 resimden 2.
      • Pull the top piece up.
      • The two gray ventilation grates will slip off the device.
      FixBot'a Sor
      Yorum Ekle
    3. InFocus IN35W Fan Replacement: adım 3, 2 resimden 1. InFocus IN35W Fan Replacement: adım 3, 2 resimden 2.
      • Detach the white speaker wire that connects the motherboard to the top piece.
      • Remove the top cover from the device.
      FixBot'a Sor
      Yorum Ekle
    1. InFocus IN35W Fan Replacement, Motherboard: adım 4, 2 resimden 1. InFocus IN35W Fan Replacement, Motherboard: adım 4, 2 resimden 2.
      • Detach all six of the cables and speaker wires from the white connectors on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus IN35W Fan Replacement: adım 5, 2 resimden 1. InFocus IN35W Fan Replacement: adım 5, 2 resimden 2.
      • Remove the six 4 mm Torx TR10 screws from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. InFocus IN35W Fan Replacement: adım 6, 1 resimden 1.
      • Carefully grasp the outsides of the motherboard and pull it up to remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    1. InFocus IN35W Fan Replacement, Fan: adım 7, 2 resimden 1. InFocus IN35W Fan Replacement, Fan: adım 7, 2 resimden 2.
      • The fan is located on the side of the device.
      • Lift the fan up and out of the projector body.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Grace Hubert
608 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Simcock Fall 2021 UMass Dartmouth, Team 1-2, Simcock Fall 2021 üyesi
UMASSD-SIMCOCK-F21S1G2
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 324
